trim gauge
whiskera
I have a 1990 nytro with a 150evenrude<br />the gauge quite on me last year<br />I replaced the gauge & im lost<br />It not working Does any body know how the circut works
D
DJ
Guest
Re: trim gauge
Mike Arnold,<br /><br />Raise the engine up. Inside the transom bracket you will see a sender that has a wire going to it. It should have an arm on it. You can test the continuity of the sender with an ohm meter.<br /><br />You should be able to see the ohmeter change, evenly, while you work that arm up and down.<br /><br />If not, most likely the sensor is bad.
Joe Reeves
Re: trim gauge
I'm assuming that the 150hp Evinrude is also a 1990 model. The trim gauge sender is located just inside the top area of the port transom bracket. It is has either failed or is stuck, or possibly one of the two wires leading from it has been broken, sheared, cut, grounded out, something of that nature..
