Trim gauge
ringo111
I was given a trim gauge with a red dial.wires colors are white./ bl/yell stripe and purple blue stripe. Anybody know how they connect up .thanks.
Re: Trim gauge
Ayuh,... To What,..??
Silvertip
Honorary Supreme Mariner
Re: Trim gauge
The symbols on the back of the gauge tell you that. I = +12 volts when the key is on. L = internal light if it has one. Ground symbol = ground. S = sender. The sender on the engine you have must match the gauge you have.
ringo111
Re: Trim gauge
for got to tell you wireing it to 60 hp evinrude
seabob4
Re: Trim gauge
On the engine end, if it has one, the trim sender will be a white w/tan stripe. You do know that Merc and OMC trim gauges work opposite of each other, don't you? Do you know if the gauge you were given is for an OMC engine?
