Re: trim gauge
Related to radio? Depends. Is there a separate wire for your radio light? Usually not. Light comes on when you turn the radio on.
First thing to check is wiring to the gauge. See the stickies up top for how things are wired. The gauge will typically have 4 wires; +12V (on when boat ignition is on), ground, the wire from the trim sender, and lighting (typically tied to the boats light switch). Usually gauges are tied together for power, lighting and ground, so if other gauges are working, these wires should be OK (though it's good to check the connections on the back of the gauge for power as wires also can flake out). That leaves the signal from the sender.
The sender has two wires. You can measure resistance between ground (wire) the sender wire and the resistance should change as you trim up and down (or move the sender manually).
BTW, I have the same problem, so this is what I've learned that I need to check. I still have not done it, so my facts and terms may be a little off, but that is the gist of it.
Looking forward to hearing more on the subject.
PS. Here's the exact location of wiring diagram. There's no Trim, but you'll get the idea.
http://forums.iboats.com/showthread.php?t=186986
