trim gauge not working right
edgar0400
i have a 2005 glastron with volvo penta 5.0 and the trin gauge keep going up almost to the up position while the boat is running the boat runs good maybe defective switch?/
farmer9009
Re: trim gauge not working right
If you trim gauge in the dash is reading incorrectly while the boat is running then this should have nothing to do with your trim switch. Does it read correctly when not running? More likely there could be a loose or corroded connection between the sensor and gauge or one those 2 parts are defective.
mark1905
Triple check all of your wiring, especially the connectors at the rear of the boat. Sounds like you may have corrosion on a wiring harness that is jumping power from your ignition + wire to your gauge wiring. I had the exact same problem and that's what it was..
Try turning the key on but not starting the engine. Does it still do it?
In any case, it's always a good idea to be hyper sensitive about electrical issues..
dishwillow
i've had the same problem before. ended up having a terminal corroded int he connector at the rear of the boat. good luck.
bruceb58
Bad trim sender. These fail all the time. I have changed mine but not going to bother after this one fails again.
pvancorenland
Mine failed too. The wires were broken from too much bending left and right.
Instead of ordering a new one and going through a major pain of swapping it out (so I hear), I just did some soldering and waterproofing of the wires (I only had to make 2 connections, not all three), and it works just fine.
I did it while the outdrive and the pivot housing were off, which made it a LOT easier.
Mine failed on my 95 maxum too, but im not to worried about it. I trim the motor out by feel and if I know it is getting shallow ill go back and make sure the drive is up enough before i proceed into shallow water.
edgar0400
so i should't be worried about being a mayor problem?
this is my first boat and as you can see i don't know much about it
thanks for the help
