Trim gauage
pav40
My trim guage stoped working on my 03 stingray the switches are working just fine
Re: Trim gauage
Ayuh,.... Welcome Aboard,... My 1st guess would be the wires at the sender, on the side of the drive...
achris
More fish than mountain goat
Re: Trim gauage
Check power AND ground are good and solid at the gauge, check the connectors to the sender at the back of the engine (which, btw is what???), check continuity of the sender wire to the gauge. Also check the harness plug is good (remove and splay the pins SLIGHTLY)...
If all that checks out, the sender's gone south....
Chris........
