Got a 98 johnson 50hp leaks down when its tilted up i had my buddy work on it to replace the seal and its not leaking...does it just need to be bled and if so what are the procedures or was it put back together wrong?
Well not sure the procedure but it sounds like you need to re-bleed the system. I have done many clutches in cars and if you are bleeding the hydraulic fluid and somehow air gets in there, you have to start all over. Try bleeding it again.
