I have a 1990 90 hp force. New to me with the trim and tilt. The tilt cylinder was leaking around the shaft so after stalking the forums for awhile and reading the rebuild post I ordered a kit to rebuild. Got it off the motor and to the shop got the trim cylinder apart went to take the tilt cylinder apart and can not get it off even with the spanner wrench. Anyone know if the caps are still available in case it gets destroyed coming apart? Also I was looking at the pump and the 2nd port back isn’t drilled is this correct? Doesn’t seem like it would feed or return one of the cylinders correctly to me but I’m a noob when it comes to marine trim and tilt. Any help would be great thanks in advance!
