Trim and tilt compatibility
bulletsaltcreek
I have a mid 90's model 60 hp Johnson. The trim cylinders are locked in up position. I've tried several different remedies and failed to get it working. I found a unit that came off and 80's model Evinrude. The unit looks identical to mine except for Evinrude color. Is this compatible? Can I just swap out by unbolting and bolting back up the other? I cannot tell if the bolt holes line up because it's for sale in eBay. Any advice suggestions are welcome on this transition. Thanks!
