Tried a 4 blade for the first time.. IL6 Merc 1350
stant1man
Got this Mach 13.5 x 18 four blade prop on my boat... It didn't seem to work <br />even half as well as my 13 x 18 quicksilver 3 blade?<br /><br />It is ported and looks really fancy.... Am I missing something, should this <br />prop not give me better holeshot. With this on, my engine revved to 5200rpm <br />and my 3 blade revs to 5800rpm.<br /><br />Not only that but when I went into gear it really seemed to thump as though <br />the prop was much heavier.... Which it is but...well...<br /><br />What do you guys recon?<br /><br />Cheers<br /><br />Stan
phatmanmike
Re: Tried a 4 blade for the first time.. IL6 Merc 1350
stan i put a 4 blade stainless on my 225 johnson v6 a few weeks back. it gave my motor a higher top speed and a bit better hole shot<br /><br />my normal prop is a 15x 17p 3 blade aluminum<br /><br />my test prop was a 4 blade stainless 19p, im not sure about the diamater though.<br /><br />i know this isnt an inline 6 merc, and i know my boat is about 4 thousand pounds heavier than yours, and i know that its about 100 hp more, but im sure its usefull none the less.<br /><br />by the way stan, i just got this for my inlne 115:<br /> http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=4576893409&sspagename=STRK:MEWN:IT
walleyehed
Stan, with the same pitch, larger diameter, it's going to drop in RPM and so is your speed unless you raise the engine up on the transom, but I still doubt we'll get the RPM back, and expect no gain in speed over your 3 blade.<br />On some boats, some 4 blades lift the stern too much forcing the bow down and actually lose speed...this may be the case.
WillyBWright
Old inline Mercs don't swing 4-blades worth a crap. But then remember, back in the day the perf props had 2 blades. Got a hacksaw? ;)
