Re: Tricks to spool up a reel with line? spincast
I use a screwdriver through the spool hole, and then stick the handle in between cushions of the couch, with the back of the spool gently touching the back of the couch (so it doesn't turn freely). Then reel on the line (usually while sitting in another chair watchin' the tube)... This helps to keep tension on the line, and running the line through the whole length of the rod (as opposed to straight into the reel) helps keep the tension even.<br /><br />First chance I get (at the lake) I put the heaviest spoon I have in my tackle box, and make a couple of loooong casts (at least 2 times longer than normal), and use a constant retrieve at a speed that puts the right tension on the line. Afer that it's ready for fishin'.<br /><br />When the small ones have been casting a lot, I find it helpful to put a piece of heavy tackle (with a swivel) and do the long cast thing to even out the tension and untwist the line once in a while. Usually done when they start having difficulty casting themselves, and it usually solves the problem.
