tri-hull
oldhull
ok.. brand new here n to boating<br />just bought 1969 18' larson tri-hull<br />dont know nuthin bout boats... cept now it's in my garage n snow is off it n transom is shot<br />i'd like to post pix but not sure how<br />tired of fishing off dock<br />this boat gonna need some(?) lotta work n these boards seem to be where to be for help<br />n e 1 know how a tri hull rides?<br />i live in Toledo Oh so lake erie n maumee river gonna be water it in<br />mmm thnx in advance<br />not much room left in garage either
alden135
Re: tri-hull
iboats just upgraded their servers. Last I checked, the search function still isn't working. When they get it fixed, you'll find a lot of info on the transom repair. <br /><br />As far as posting pics, you have to use a hosting service like photobucket.com.<br /><br />Once you upload them to the hosting site, you can include them in your post by using the full reply form and the image tag.
oldhull
Re: tri-hull
thank you..alden, yes i've tried searching 'bout transom repair and got nowhere<br />i left navy in '63<br />i'll try pix nxt.. wish me luck
alden135
Re: tri-hull
Originally posted by oldhull:<br /> i left navy in '63<br />
They stopped using sails right after 1963 :D Thats the year my Dad got out. USS Klondike AR-?<br /><br />To post a pic try clicking the image tag, then copy the url into the box, this should happen...<br /><br /><br />
<br /><br /><br />There are a couple other ways but thats what I do.
alden135
Re: tri-hull
Also, I was looking at your pics and I'd like to get a tri like yours for myself. You can often find them for free around here. <br /><br />I have a perfect running 1969 85hp evinrude that needs a boat. I'd like a second boat for use as a work boat.
JasonJ
Re: tri-hull
The way a tri-hull rides depends on its design. You will hear that tri-hulls all ride bad, are slow, and heavy. There is a degree of truth to that, but these statements usuually come from those who have limited experience with the design, and only regurgitate information that they heard from someone else.<br /><br />The way the boat rides, even as a tri-hull, depends on the amount of deadrise the bottom of the hull has, and the size of the outer sponsons. Deadrise is the amount of V the hull bottom has, the sponsons are those outer parts of the bottom on each side. The less V the bottom has, the rougher it will ride. I looked at your hull, and it appeares that it has a pretty shallow V to it, so it is going to have a moderatly rough ride to it. Also, the ride depends on how you drive the boat. Just running wide open and slamming through is not what you do with this hull design. Run speeds that are more reasonable and do not hit swells or chop head on, and it will ride reasonable. The advantage this hull design has over other designs is stability. It is very difficult to have instability while in motion or at rest. It can turn harder at faster speeds as well. At rest, it is rock solid, very little tipping, which is good for fishing.<br /><br />If you click my link and read through, you will see what can be done with a tri-hull. My boat was manufactured in Minnesota and was geared towards the rougher water. Because mine has a lot of V to its bottom, it rides as good as a V hull at speed, but handles better in turns.<br /><br />One downside to tri-hulls is weight and wetted surface. There is more fiberglass in the construction, and during the time period these were made, they used more material. You end up with a strong hull, but it is a heavy hull. Also, there is more wetted surface, which equals more drag. Wat this all means is you need more power to make up for the drag and weight. I have 125 horsepower on a 17 foot tri-hull, and I am pretty happy if I break mid 30s in miles per hour. This same motor on a V hull of similar length would get me well into the 40s. That is okay with me, as I am not out to break speed records.<br /><br />You have not mentioned what outboard motor you have, if any. I will recommend 150+ horsepower for that size hull, anything less may make it too slow, especially if you are running on Lake Erie, you want to be able to get out of the weather quick. Like I said, click my link, it describes my tri-hull rebuild. Good luck...
Terry Olson
Re: tri-hull
Tri-hulls tend to ride rougher than others because they skip across the waves rather than cutting through them like a v-hull does. On the upside they offer more useful space at the bow of the boat without adding to either the overall width or length and they're more stable in the water. All in all, I like a tri-hull and the only reason I don't have one is that I like the benefits of an aluminum boat. <br /><br />I'm sure JasonJ will weigh in and you should check out his tri-jull project: <br /><br /> http://70silverline.250free.com/Skankybeast.html <br /><br />When the search function comes back online you should look for transom repair, floor repair, stringer repair. You'll get a good idea of the likely repairs you'll have to make. It's a big job, but it'll involve a greater investment in time and effort than money. <br /><br />Good Luck.
oldhull
Re: tri-hull
thank you everyone..<br />this boat strickly fer fishing ..me n me old budz<br />go out catch fish come back we toooo old fer the yungnz<br />no motor yet hoping a 20- 40 hp handle the job<br />alden .. how u get that picture in here like that??<br />USS RANGER CVA-61 we caried the flag for the seventh fleet
alden135
Re: tri-hull
Originally posted by alden:<br /><br /><br />To post a pic try clicking the image tag, then copy the url into the box, this should happen...<br /><br /><br />
<br /><br /><br /> [/QB]
You need to use the "full reply" form to get to the image tag
oldhull
Re: tri-hull
JasonJ nice job "What followed was a nightmare beyond comprehension." am i looking at that too??<br />shud i remove the floor ? am starting to remove anything held with a screw. i'd like to have just a single side console on the right<br />mebe me n 5 uthr dewds will a 40hp get us thru the water ok?
oldhull
Re: tri-hull
alden that 85hp work ok for me too<br />can we get together on that($$??)
alden135
Re: tri-hull
oldhull,<br /><br />Nice job on the pics they look a lot better. :) I'd leave consoles and just restore to original if it were mine (but it's not :( ). This being your first boat, you already have a lot to do to be ready in 4-5 months. <br /><br />Sorry, but the evinrude isn't for sale. For some sick reason, I really like the old dinosaur. Lots here say the electric shift gearcases suck, but mine workes perfectly. I paid $80 for it and bought maybe $100 worth of parts + paint. You should be able to easily find a motor for cheap where you are. I would agree w/others that you need something with some power and a 40 won't do it beyond headway speed.
Indymike
Re: tri-hull
I like my tri hull. Very stable fishing platform.<br />You are going to have to hustle to have it ready for spring. If your transom is toast take a good look at the sole.
EZLoader
Re: tri-hull
Old Hull,<br />Take a look at Indymike's link at the bottom of his post above to see his boat and restoration pictures.
oldhull
Re: tri-hull
EZLoader, Indymike, alden, JasonJ, Terry Olson<br />thank you for all this <br />best CHRISTMAS gift ever<br />YOU ROCK
JasonJ
Re: tri-hull
Oldhull, it's too bad you aren't closer to me, I have a 69 115 horse Evinrude just sittin' and waitin' for some use. You can try a 40 horse if you want, but it will be misery. It probably won't plane, but I guess it'll get you on the water.<br /><br />It wouldn't surprise me if you had to do a rebuild of the floor/stringers/transom. I have the feeling the thing was left out in the weather all the time, and that is what kills boats. Good luck...
