Re: Tri Hull Open Bow Deck
Bow deck cover continued:
A little ocean going boat next to a bigger ocean going boat. Inn't it so cute??! This is a "proof of concept" trial season after which improvements to it will be added during the upcoming winter.
I think this will be pretty much a single post but we'll see. I haven't seen one of these built but I wanted it badly on this boat.
This tri hull is a 1977 Orrion 15 footer powered by a modified 1975 Chrysler 85. The boat is used 99 percent of the time in the Pacific Ocean out of Humboldt Bay. The ocean up here is notorious for unforgiving conditions but in the summer, it can be very nice. Much of the time I have to tolerate 7 to 8 foot seas with some wind chop, occasionally sending water over the bow on a little boat like this. It also can rain in the summer, and the open bow just collected water and drained into the cockpit. I wanted to be able to stand on the deck for fishing, launching and retreiving the boat at the ramp. I also wanted to be able to open it for full access to the contents of stored items in the bow compartment, and I wanted to be able to remove it quickly for open bow use if necessary. Stiffness was the key.
I spec'd it for 1 inch thick marine plywood fiberglassed on both sides for rigidity, air vented it for portable fuel tanks in the bow compartment, and slide off hinges. The 4X8 sheet of plywood was a little over 100 bucks. Marine grade ain't cheap. Nice wood though. After a summer in the Pacific Ocean this summer, I haven't regretted going with it one bit.
With that said, pictures pretty much tell the story. This boat is not restored and probably will not be. It is strictly a utilitarian recreational fishing boat. If a hole needs to be drilled, I drill it. No worries about scratches, I don't care. It's strictly a bang for the buck proposition and has spectacularly exceeded any expectation I've ever had. I've landed over 35 Pacific Halibut ranging from 11 to 60 pounds and numerous ocean Chinook Salmon along with a host of others. The boat was 500 bucks, the original 85 Chrysler was replaced with a 40 hour old 85 that I happened to find in a guy's back yard who I know, for 75 bucks, all fresh water time in perfect shape. That engine now has 460 hours on it, all salt water Pacific Ocean time. The boat has a rotten transom and has for the last 4 years that I have owned it. That will likely be corrected this winter but has not hindered the boat's functionality. No stress cracks anywhere in the transom. Do not take this to mean that you can safely operate a boat with a known rotten transom. This one has known good spots in it, and still has what I've determined to be adequate strength for what I do with it. Not all rotten transoms can be operated safely if at all. This decision is yours to make, so don't rely on my information here. Operate at your own risk.
It all started with the open bow boat and a piece of plywood. The boat has the hand rails removed. Hand rails are required for passengers in the front. I am not going to carry passengers in the bow compartment, so off they came. Fuel tanks are strapped to the seat bases and plumbed for supply AND remote venting. Quick disconnects to the aft supply disconnect that normally connects to the stern tanks allow feeding off of rear or front tanks. The front tank vents are connected to one rear tank vent, so all 3 vent from the same vent on the port stern tank. On this boat, either engine can feed off of any tank. I can run 6 tanks for long runs of over 150 miles for tuna if I want to. I get about 30 miles per 6.5 gallon tank filled to 6 gallons.
The sheet was set up where I wanted it and cut to match the entry door and window opening.
Side view showing blocks holding the sheet in place.
Window closed, perfect fit along the bottom.
