Travel Trailer
clanton
What are the brand names of well built fifth wheel travel trailers 28/40 ft? Not doing much traveling, a getway place near the water, but easy to move.
cajun555
Re: Travel Trailer
Clanton, Theres so many different brands of T/T on the market. I used to have a Prowler years back. It was ok. <br />We used to go up to the used trailer lot to window shop. It seems a used trailer lot has a lot more to choose from, and gives you a lot of ideas of what you might want.<br /><br />The only draw back on the fifth wheels is the master bedroom is always at the front and not as much head room. It seems that bumper pulls have a lot more floor plans to chose from.<br /><br />Next would be your tow vechicle, Most fifth wheels require at least a 3/4 ton truck as fifth wheels have a much greater tounge weight, where as a bumper pull, if your not going to pull that often a 1/2 ton truck with the correct sized load distributing hitch will sufice.<br /><br />good luck on finding what you want
