transom
tim9613366
I have a 1987 Sunbird Corsair I/O, 3.0 litre, 4 cyl. Mercruiser. The boat is in great shape with the exception of a bad transom. The top of the outdrive now has about an 1/2" gap from the transom. What is the best method to replace the transom? Seacast? And, how labor-intensive will it be? Lokks like a real pain to me. Any suggestions would be helpful. Thanks.
Wimperdink
Re: transom
Do a search in this forum for Transom Repair and read your lil heart out for days.. then hop to it.
epresutti
Re: transom
Tim,<br /><br />Echo what Wimper.... says. You may also find same as many, transom, deck, stringers, etc.... <br /><br />Good luck.<br /><br />Ed.
Re: transom
Nah,.... Not Really...............<br /><br />Pull the Outdrive,....<br />Pull the Engine,.......<br />Pull the Transom Assembley,.......<br />Cut Out the Rotten Transom,........<br /><br />Then put it All back together...........<br /><br />Seacast is Not an option,.........<br />
VERY,.......... Especially if you're Paying somebody Else to do it............<br />No Doubt,.. Way More than a 1987 Sunbird Corsair is Worth,..... Even on a Good Day....................
Wimperdink
Re: transom
Originally posted by Bondo:<br /> <br /><br />Pull the Outdrive,....<br />Pull the Engine,.......<br />Pull the Transom Assembley,.......<br />Cut Out the Rotten Transom,........<br /><br />Then put it All back together...........<br /><br />
:cool: This needs to be listed as the standard 5 step transom repair manual. :D
bosavy
Re: transom
Alot of work ahead for you. Do what;s listed above and then take the trim off and then the fun starts.I used a plumbers 3 quarter inch drill bit and drill small holes and make sure your not off center. then chip away and use a vacuum to get the access. Buy marine plywood and i used west marine expoxy and alot of clamps. Average cost of a marina is 1000 to 2 ooo
agitator
Re: transom
I repaired the transom of a 20' center console with Seacast. While I was at it I poured a couple of extra stringers in the back alongside those that were already there and I think O.K. and tied into the transom. Lifted off the outboard engine, cut off the glass cap on the transom and removed the old wood from inside the transom with a chainsaw. Poured the Seacast, recapped the transom, rehung the engine and you can barely tell it had been touched. Would do it again in a heartbeat. Less work, looks better, stronger, impervious to water and will last forever. Seacast "not an option" my a$$.
Re: transom
Originally posted by agitator:<br /> Seacast "not an option" my a$$.
He's got an I/O Mercruiser,............<br /><br />Seacast is Not an Option,...............<br /><br />You have to preserve the "Hole" in the transom,........<br />And,....... Have the Finished Thickness between 2"s,+ 2 1/8th"s......................<br /><br />The Effort to do this with Seacast would be More Work than Doing it Right.................. :rolleyes:
tim9613366
Re: transom
Thanks everybody for all of the suggestions...maybe I'll just let it sink instead!
