Ok so I am thinking of adding one of the transom brackets on the inside of my transom to keep the screw washers from "digging" in and to keep the trolling motor I was given from messing anything up. My question is this is it worth it? Also cant I just go get some thin metal from home depot and mount it in and be doing the same thing? I am just thinking this for preventitive maint since my dads first older boat had the washers on the inner/upper bolts crack the transom. I figure if it really helps and spreads the weight better then it is worth it. Am I on the right track of thinking here?
