Can Gluvit be used on the outside of a transom as well as the inside? I have a good many pin holes on both sides of my transom (1442 Grumman jon boat manufactured in 1988). I suspect that pressure treated wood was used for the core and I will attempt to replace it with plywood coated with fiberglass resin. The boat was used in brackish water conditions so I suppose some of the corrosion could be from salt water. Anyway, after I replace the core I would like to seal the entire transom with Gluvit and then paint the entire boat. Can Gluvit be used in such a manner? Any input will be greatly appreciated.
