transom troller mounted on bow kicking up
cranecrane
Hope someone a whole lot smarter then myself and husbund can figure this out for us. We have a 34# thrust Motorguide trolling motor purchased in 1997 Model HVT4300. (36 inch shaft) This came with a K&L little fishing boat call the pro 120. When used in the past (rarely) it was used on the transom of this boat which is only about 12 feet long. Motor was stored in house and appears to be in great condition. With the boat came steel plates from K&L to mount the motor on the bow if we wanted. This was installed last week properly, and the motor head turned around, etc.but when we took her out on small local lake the motor kicks up out of the locked position into a higher notch controlled by a push spring pin. Are we doing something wrong? Can spring be tightened down? Nothing in the generic Motorguide owner's manual. Our boys now 18 want to use this boat, but not until we know what is causing this. It happens when you increase speed at about the 3 mark (setting goes up to 5)
Thanks for anyone's knowledgeable input. Note that pic attached is newer model old model did not have built in bow mount, thus the steel plates.
