Transom Straps
sixgun95
07 Chaparral Sunesta 214 - 1st boat, it did not come with transom straps. When I got home I put them on and they rub against the boat. Is this normal? Will mark up the gel coat? It seems that if I move the winch post forward approx. 1" the straps will clear the transom. Any reason why I shouldn't do that?
jtexas
Re: Transom Straps
It'll increase your tongue weight by a wide margin - you'll have to move the axles to compensate. you know those padded things people put on their seat belts? might work.
tashasdaddy
Re: Transom Straps
i have seen people wrap a towel around the strap, and put duck tape on the towel to hold it. red neck but the boat ain't scratched.
CATransplant
Re: Transom Straps
Or, you could do what my father always did when he bought a brand new pickup. He has a citrus farm. He'd buy the pickup, then drive it down a couple of orchard rows, so the tree branches would scratch up the sides of the truck.
He figured that it was a work truck and was going to get scratched up anyhow, so he just did it right away so he wouldn't worry about it. :D
Silvertip
Honorary Supreme Mariner
Re: Transom Straps
If the straps are tight and the boat doesn't jiggle around, they won't bother. Mine have soft rubber pads that rest agains the boat.
rndn
Re: Transom Straps
Use something to pad it, but I'm not sure moving the boat by only 1" will make a significant difference.
Nova II 260
Re: Transom Straps
If they're tight they shouldn't rub. Put a piece of cardboard under them on the corners. I'm with RNDN, moving 1" won't matter.
boatflounder
Re: Transom Straps
try the straps from west marine, they have pads attached, and while my boat doesnt rub, it seems like they would help in your situation.
KM2
Re: Transom Straps
When put on snuggly they won't move and therefore not cause any cosmetic problems. Most boat/trailer combinations work like yours. Never had a problem with mine in 6 years.
kenmyfam
Re: Transom Straps
I use some old carpet underlay. Works great.
Rob454
Re: Transom Straps
Just have a welding shop make you some eyelets that stick out past the back of the hull by 1 inch or so. then use the eyelets to hook the transom straps to that.
Rob
