Transom Seal for Shift Cable Housing
Horigan
I'm starting to chase down a minor fresh water leak in my bilge. One area I want to investigate is the seal where the shift cable housing exits to the outdrive. I remember the cable housing feeling a little loose through the transom when I did my annual service last fall. I've scoured the BRP catalog and can't find where this seal exists. My outdrive is an OMC/Volvo joint venture SX, per my signature below. Can someone point me to the part number for the seal? Can this seal be replaced without RnRing the transom mount?
muc
"Retired" Association of Marine Technicians...
you will need a very narrow wrench. I ground a harbor freight down to fit.
3852537O-RING, Sleeve & connector
The part number is found in the transom mount section.
