transom saver question
tav
soon i'll be getting an 8 h.p 4s and thinking of useing a transom saver .
the cross member that runs acroos the back of the trailer is 3 " thick are most transom savers able to fit that thickness ? are there different sizes for different trailers?
Re: transom saver question
If you can safely tow with the engine tilted fully down you don't need a transom saver. But if you don't have enough road clearance and the engine must be tilted, then they are a good idea. Transom savers generally have a couple of different attachment methods to accommodate different trailer frames.
lckstckn2smknbrls
My TS mounts to a keel roller at the rear of my trailer. Others have a pin or nub that bolts to the rear cross member.
tav
my roller is in plain sight and that might be a better method, is there a brand name for that one? wait a min. i thought i saw them at cabelas the other day. that might be them. thanks
22E6441
roller mount is only for motors with power tilt and trim
you need a bolt on, which is fine (i actually trust them more)
