barney35226
- Aug 17, 2003
- 4
Hi,<br />Rotten transom on 15.5 ft. Fabulgass/~1975/115 evinrude with splashwell. The transom is rotten all the way up to its top corners. This forum has been great educating me on transom repair. Here is my dilemma. Someone enlighten me please. The simplest method of replacing transom seems to open it up by cutting into the splashwell and replace transom from inside, then rebuild the splashwell. But if I find my stringers to be rotten once I'm in, then I'll need to remove cap and deck to replace them, right? Then my damage to my splashwell would be in vain; I'll have to repair the splashwell as well as replace the deck, right? If I go ahead and remove the cap, can the splashwell be removed separately from the deck, then allowing the same access to transom without ripping into the splashwell? Any advise welcome.
