oldscout50
- Sep 23, 2004
- 8
I have started working on the repair to the 78 Skeeter bass boat. I removed all of the bad wood clear down to the soild wood at the very bottom of the boat. I sprayed in the CEPS to seal the rest of the wood. I have cut one piece of new transom plywood. When I test fitted the wood I found that the stern has a slight curve to it. It also only has about a 1" gap between the inner and the out fiberglass. I had already couted on putting a piece on the outside and the inside of the boat to cover up some mistakes that were made before I got the boat. I do not think that I can get both pieces of plywood in to the transom area with them apoxed together. Do I have to apoxy the two new piece first or can I put them in and them do it? The one repair that I read about had you pouring i apoxy mixed with sawdust to fill the areas around the new wood.
