Re: Transom repair/replace 1957 starcraft fury
Hey thanks for the reply-
I got that far into it thinking I was going to do a seacast transom, by cutting the back fiberglass where it wasn't cracked or gone already, removing the delaminated plywood, then somehow clamping a temporary piece on the back to contain it, then filling with seacast and sanding, finishing and painting.
Fortunately, that went well, got the rotten/delaminated wood out and ground down to the inner skin with little effort.
BUT, theres more problems---see Pics--
http://picasaweb.google.com/113783896709077845656/BoatPics3#
Tore the carpet up and found some rotted plywood/cracked fiberglass screwed to the floor.
Tore up the delaminated fiberglass/plywood and found black wet mushy plywood.
After tearing the carpet off, and then the cracked fiberglass along with the soggy,slimy,plywood deck, I see the front plywood of the deck is rotten, completely gone, and it looks like someone had replaced it at some time using plywood bits and toggle bolts, then badly applied fiberglass, perhaps why it cracked and let water inside.
As you can see in the Pics--
It looked at first to be a fiberglass stringer but theres some rotten wood, about an inch inside one of the stringers...
And, theres rotten wood inside the cross brace in the pics.
Is there supposed to be a piece of wood under all that glass? the fiberglass is about 3 1/2" tall, but all I saw there was about an inch of rot. Didn't see much of anything through the screw holes in in the other stringers.
Found what I think was a mouse nest in the area. Perhaps thats what chewed up the fiberglass stringers..(see pics..)
Tore the fiberglass back further off the floor and found good plywood..
Is this old barge worth fixing?? I need 6 gallons of seacast for the transom, about $300+ , and whatever $$ to fix the stringers and deck.
Im just wanting a 2-4 person lightweight boat that will go fast with a 25-40 hp motor..The "Fury" seemed just perfect until I found all that rot in the transom and floor.
anyway, Is it worth fixing, or could I buy something I would want for the same I would cost me to fix this old barge?
Chad_E
