Marcel1952
- Aug 24, 2015
- 24
Hello all on this great forum.
I'm living in Sweden so forgive me when I write in poor English.
I recently got a bayliner 1952 capri cuddy cabin for free with some issues.
The deck has soft spots and the outboard drive is shot.
A lot of TLC so to say.
As I was dismanteling the deck to look deeper in the boat, I found that the foam on starboard side was smelling like gasoline.
I got the tank out and did a pressure test and seems fine so I think it's from spillage or a earlier rotten hose to the tank.
I drilled some test holes and the stringers are still rock solide so thats a refief and saves me some work.
However when I lifted the engine and gimbal unit out I saw that there is some delamination from the outer skin and the plywood just at the bottum of the keyhole.
So i'm afraid that the transom has to be replaced.
Now here is my question:
Looking at the inside of the engine bay I see a thick part on the transom where the keyhole is cut in ( approx 50x60 cm ), next to that its thin again.
After taking out a bolt on the thinner side it looks like its only polyester and no plywood at all.
Did anyone here a simular repair and is it correct that there is only plywood on the transom within the width of the stringers?
If possible some pictures of the repair would be appriciated.
Hope someone can get me in the right direction.
Marcel
I
Marcel
I
