Keithmichigan
- May 19, 2013
- 7
Hi. I just started yesterday to replace the floor and transom on my 1988 Starcraft islander 221 v and I already have the engine,outdrive and transom off. I did not expect to get this far so soon but I'll take it. I had planed to use the 60$ Dr.rot layup & laminating resin between the 3/4 sheets of marine grade plywood and I am wondering if this is needed or should I just use a waterproof wood glue as that's what the plywood layers are glued with? I was planning to use 2 coats of Dr.rot CPES then 6 coats of helmsman spar varnish. I will post pics as soon as the wife or kids are available as I'm not very computer talented. So do I use the waterproof wood glue or the laminating resin? I am not worried about the 60$ cost I just wonder if its needed? Any other suggestions are always great. THANKS.
