Freedom190
- Aug 21, 2016
- 2
Ive got a 1990 four winns freedom 190 with OMC motor and lower unit. The transom is rotten so before I removed the rotton transom I measured it and it was 1 1/2" thick but everthing I read on here and everywhere else I get different thickness anywhere from 2" to 3". Right now I have 3 pieces of 1/2" plywood glued together so if i add the 1/4 thickness of the hull and after I glass it with 1708 and chopstrand does anyone know if im going to be at the correct thickness for this boat or should I add another 1/4 of plywood?
