Re: Transom height performance difference
I have gained dramatic changes in rpm, top speed, and economy with massaging of the motor height. I plan another 1/2 inch adjustment, which will then allow me to step to a 19 inch prop. The adjustments I have made so far have me at 6000 rpm with just me in the boat, wide open. I figure if I can get a few hundred more rpm, I can then step to the 19, which will bring me back down around 6000 rpm, and should give me a speed increase. I have spent a lot of time tweeking my setup, as I don't have power trim. I am getting closer to what I think should be optimum. I have also had to do a lot of set up change because of adding more stuff which equals more weight and different load distribution.<br /><br />If you can get your cav plate even or a half inch above the keel, you will then be able to tweek with trim angle and prop. You will need an accurate tach though, otherwise you will have no idea if you are making progress with your tweeking. Good luck....
