BoatRookie73
- Mar 12, 2011
- 9
I'm new to boat ownership. I bought my first boat 2 years ago, it's a 1988 Polar Kraft. It's a 17ft aluminum bass boat. I've got a feeling that I was taken for a ride on it. I just had $250 worth of motor work done in it. I noticed when I got home and was loading my stuff back into it that the transom is starting to separate from the splashwell. If you lift up on the motor you can see the transom flex. The previous owner told me that he had replaced the wood in the transom about a year before I bought it. I've owned it for two years, but it's only been in the water about 5 times since I've had it. I do have a transom saver on it so I know that the transom isn't taking on all of the weight of the motor. I don't know what could be causing this. It's the original motor to to boat, so I know that it's not too big of a motor for it. I guess my main question is what are my options on getting this thing in running order, and can it be used the way that it is. Or is that too risky? I will try to post pictures on this. Any help will be appreciated!!
