Transom drain plug assembly replacement
bigjimbok
I have a 1987 Lund Tyee 4.9. The transom drain has a leak between the collar and the transom. Can anyone advise how to replace the entire assembly and where I would get one?
bigjimbok
Re: Transom drain plug assembly replacement
Thanks for the reply. None of the assemblies match what my old Lund has for a transwom drain. I have a 3/4" rubber t tighten plug and the drain tube it goes into is aluminum with a collar inside and outside. This is what leaks, transom is sound.
LippCJ7
Well I think it would be better for someone more familiar with your setup to comment, and that probably will not take long so Good Luck!
Bob_VT
Seal the collar with 3m5200 ........... The only way it will be replaced is with a welder since it is an aluminum hull.
