transom clamp screw/swivel plate fix??
nwcove
has anyone come up with an effective,lasting fix for re-attaching the swivel plate (cup) to a transom screw??
Joe Reeves
Re: transom clamp screw/swivel plate fix??
Yes, OMC did. It requires a special tool and the washer retainer of course.
The alternative is to install the new type swivel clamp that incorporates a threaded hole in the center rear portion of the threaded shaft and a related threaded shoulder bolt to retain the washer.
Exactly what engine are you speaking of?
nwcove
have a couple with that problem, but the one id like to fix is a 1966 jw-21, i do have the original swivel plate
boobie
I've put those retainers on with the right size socket before. Best thing to do is get the new style clamp as Joe suggested.
kodibass
Master Chief Petty Officer
I just file the clamp bolt end flat used a small peen punch then drilled a hole tapped it and bolted on a cup, I'v done a few this way and never had one fall off yet, I do put a dab of thread lock before bolting on the cup,
boobie
Another good idea. No kidding.
