Transom bracket interchange question on 1971 40 horse.
Davidius
Hello all. I have a 1971 Johnson 40hp outboard (40EL71B) and it has the clamp on bracket with no provisions for mounting bolts on the lower legs. I have sifted through parts diagrams but I just don't know enough to even guess with any certainty if it will work. Does anyone know if there is a transom bracket that will interchange with my engine that is bolt on only with no transom clamps or at least brackets that have lower bolt holes? Thank you.
hardwater fisherman
I have a 1976 40hp. The clamp screws where always backing out. I used long U bolts. One on each side. If you try this just make sure to keep them out of the way so the motor can tilt. Also you can adjust the height without drilling new holes when done like this.
F_R
Honorary Supreme Mariner
David, check the parts books for a 1960's era 40hp Electric Shift. You will find a clamp for the lower end of the brackets. It doesn't actually keep the motor from coming straight up, but it does keep it from moving side to side or outward. It was intended to be used with a transom plate under the clampscrews to keep it from coming straight up (also shown in the parts book). It was necessary on the Electric shift motors because of the additional steering torque in a hard turn.
