Re: Transducers too low?
neil2fish<br />Rooster tail is likely caused by transducer.<br />Really depends on the type of boat your have.<br />Aluminum boats with lots of rivets the transducer needs to be mounted deeper to get below the air bubbles caused by the rivets. Deep V boats then you can not mount it flush with the hull as it would be pointing off to one side. It needs to point stright down and about 1/2 of the transducer should be below the hull, so on deep V boats one side should have half of the transducer below the hull but the other side will be deeper.<br /><br />At trolling speed can be even with the bottom of the hull and will work fine. As speed picks up need to be deeper and have at least 1/2 of the transducer below the hull.
