Transducer help
joekarpowski
When I purchased my 2001 Pro-Line 22Walk from a guy in GA 3 years ago it came equipped with a MagicBus i5500 Multi Instrument system. Everything needed to complete the system EXCEPT the Speed/Water Temp transducer and the Depth transducer was already installed. I am unable to find the transducers I need for this system. I've Googled it and even e-mailed Teleflex Morse with negative results. Can anyone point me in the right direction to find what I need to get this system up and running? Thanks!
Joe
:cool:
Pez Vela
Re: Transducer help
Airmar's "smart sensors" are NMEA2000 compatible and should work for you. Choose from the P39 transom mount or the ST800 thru-hull. These provide the depth/speed/temp that you are looking for.
joekarpowski
Re: Transducer help
Thanks so much! I've emailed Teleflex Morse but can't get any reply. I will look at Airmar. Thanks again!
