Traker 1989 70HP Pro Series 3rd power head!
galentefrogman
I bought (a fresh water) 20' partybarge pontoon w\Traker 70 HP Pro series motor that had about 15 hours on it since new. The guy I bought it from told me that the dealer replaced the power head -because pistons and cylinders scored & Head pitted. (Motor looks like new in and out). Then the owner moved to east and new power head lasted all of one afternoon before same problem showed up. Dealer over 1000 miles away wanted nothing more to do with this boat. Then I bought it. I gave it to local rebuilder he put in two new pistons, head, and reboared the cyls. Willing to give me one year warrentee. So who knows what happened to this motor? Sorry to say that I have no faith in my rebuilder. He has told me that this 3 cyl Tracker is not a good motor never was. That I should remove the oil injection and just use mixed gas. That this motor was not ment to be run wide open and that if I do run it open it will not last one season. It's going on a 21' carolina skiff, flat bottom, with nothing but me and center console and fishing pole in it. He has told me to baby the motor so that I might get about two seasons out of it. So far I have paid $1,800. for the rebuild and $500. to hang the motor + parts! Way too much money for the job I think? Who knows what I should be paying for this work? Any advice about removing the oil injection and do I have to baby this motor?<br />Thanks
Dhadley
Re: Traker 1989 70HP Pro Series 3rd power head!
Welcome to the board!<br /><br />That motor is a very good design. Do a search and you will find several long threads with real good info.<br /><br />First of all we need to find out what is causing the scored pistons. Keep in mind a scored piston is a result of something -- not the cause. <br /><br />There were several upgrades for that style motor, make sure your rebuilder does them.<br /><br />Make sure the motor is set up properly. They dont like to be lugged. Your target rpm -- with an average load -- is 5800 to 6000. They hate spark plugs that are not Champions and will revolt if non-Champions are forced upon them. <br /><br />Find and treat the cause -- not the effect!<br /><br />Good luck!
rodbolt
hello<br /> Gotta agree with DHadley on this. the 3 cyl OMC from the 70's up was one of the most durable outboards ever. pontoon boats had a terrible problem with water mist and therefore ingestion tearing up pistons. I have several crabbers that go everyday and the motors are still original and they are all in the early to mid ninties.one of the v-4 looper engines I overhauled in 98 has run over 10000 gallons of gasoline throuhg it since 1999. if the overhaul was done correctly and the setup is right the oil injection serviced then it should last for years and years.I ran a 1975 70 evinrude over 10 years myself.I sometimes think it may help to jet the somewhat richer than stock but not more than 2 or 3 sizes. good luck and keep posting. watch the tach and make sure with a normal load it will turn at least 5200 to 5500
