trailor lights
BURNSY23
does each taillight have to be grounded or will just one ground up front work for both lights? Thanks!
sunrunner190
Re: trailor lights
If each light has a good ground to the frame you are ok. The ground contacts can go bad over time and have to be cleaned up. Check all your ground contact points.
BURNSY23
Re: trailor lights
but the lights only have 2 wires, brown/yello, and brown/green, coming out of them. How are they grounded?
JBow
Re: trailor lights
If your lamps only have 2 wires they are internaly grounded. The ground is made when they are bolted to the trailer frame. Something that is often overlooked on old tilt trailers is that the coupler part of the frame does not have a positive ground conection with the rear tilt portion and they need a jumper wire installed to make a good ground between the 2 parts. Just a little something to think about.
freeisforme
Re: trailor lights
I normally run an extra ground wire from the white wire back to the lights, this eliminates issues down the road and if you trailer frame tilts or bolts together, this gives you a direct ground to the tow vehicle's plug.
bruceb58
Re: trailor lights
Just make sure every light has a good clean ground. It grounds through the mounting studs. Grind the metal so its bare, install the lights and either paint over them or apply some grease.
If you run the extra ground wire to the mounting studs, you have just doubled the complexity of your wiring and its going to double the work finding the problem when your lights eventually stop working. Its unnecessary.
Re: trailor lights
JBow is right. I ran into this issue on my trailer with the grounding problem and it took two days, replacing all lighting and both truck and trailer connections to figure this out. We ran a jumper wire and hooked to the rear section of frame and it worked.
Wingedwheel
Re: trailor lights
When all else fails, read the writing on the package thats normally there to explain these things.
