trailer specs for eezy loader trailer
swimmin' for shore
The title says it. Does anyone know where I can find the specs for this? I've googled it, but I haven't found anything. 1980 trailer 21' boat on it. No spec plate, though. Thanks.
amirm
Re: trailer specs for eezy loader trailer
Have you tried calling them? They may be able to look it up. You may be also be able to get an approximate value by looking at the max rating of the tires.<br /><br />Amir
gutshot grouper
Most tandem axle trailers have 3500 lb. capacity axles under them but your 21ft. boat probably doesn't weigh over 4000 lbs at the most, my trailer and boat together weighs about 5k lb. and the trailer is 800 lbs. Likely your boat is not this heavy unless it has an inboard engine.
fondafj
If it has brakes it probably is over 3000lb GVW. To get an idea of the rated load you can add up the tire load ratings --- most manf don't overspec their OEM tires much beyond the rated capacity of the trailer.
