trailer size?
bushanic
It came with the boat. So for these year i hope it will do. The boat is a 16ft Larson tri hull. I try to pull the boat forward but I dont know if I am going to far. Can the trailer crank go behind the bow support if so I might get it all the way on then. My goal is to try and use a transom saver. but I dont want to but to much weight on the tongue. also is this the best kind of trail for a tri hull? Here are some pics I think the trailer is a load rite 1200-L (?) What advice do you have. Thanks
Silvertip
Honorary Supreme Mariner
Re: trailer size?
Ideally, for best support the boat should be pulled foward so the stern is about 1 inch forward of the end of the bunks. The winch post looks like it can go forward 6-inches or so which would be better. You ultimately want 10% of the loaded weight on the tongue for best towability.
