Re: trailer light's won't work
As already said, you have a break in both the green and yellow wire somewhere. Get a test lite w/ the ice pick type probe . Take the tlr plug apart and see if you have power where the green and yellow wires connect to the back of plug. If you have the flat 4 prong conn, start probing the green and yellow wires next to plug, if they both have power then start probing them as you work your way to the back of the tlr. If they go inside the frame and have power at the front end but none at the back, then it's time for all new wires.
Hop this helps,
Mike
