rexmitchell
- Sep 30, 2009
- 78
I've searched and looked at at least 15 threads but nothing with the exact problem I'm having. Here is the story of events. Right running light goes out, turn signals/brake lights/side lights/left running light still working. Right bulb terminal is toast but is still working for the brake light/turn signal(it will have to be replaced but thats not my problem I don't think). After getting a new bulb in the right, now the left running light (along with the right) and side running lights no longer work, both brakes and turn signals do though. I checked the connecting wires, and my extension was bad so I replaced. Still nothing. I checked the ground, its good and I checked my truck harness and fuses, all good. I'm stumped because one: the left light was working and now stopped, and two: because I can't seem to find any wiring that is torn up or loose. Do the running lights work in sequence so that if one is bad they both are? I can't figure out what happened between the time the right bulb was replaced and the left light going out. Could the right terminal impact the left? As I said before, the right will have to be replaced but is that what is causing the left to not work?
Thanks, Rex.
Thanks, Rex.
