Trailer hub/rotor combination
shaneomac111
on my Champion 187 trailer. it appears to be like the hub/rotor combo on a car. if not where can i get them and brakes fo rit?
nlain
Re: Trailer hub/rotor combination
I would check iboats first, if not then you can pull the pads and take them to the local auto parts store and get them to match them up. Most will have a set of pictures, in a book or on a computer, they can measure and match to. If you need hubs and rotors I believe that Champion has their own website.
bruceb58
Honorary Supreme Mariner
You need a much better picture. If you are wanting to replace the rotors if they are worn, you need to figure out who makes the brakes. The easiest way is to take a good picture of the caliper assembly and someone can identify it. Or, you can call the trailer manufacturer and ask them what they put on it.
Sometimes, its just as inexpensive to buy a whole new assembly for both sides.
shaneomac111
this is about as good as it gets until i get the tools to take the calipers off.
bruceb58
So what is the problem with them right now?
shaneomac111
Found the Problem it was my caliper it locked up. Still gonna get my rotors machined b/c they are very rusty..
dirtmod61
If the rotors aren't gouged, don't turn them just to remove rust. It will disappear the first time you apply the brakes. Wait to have them turned until you do a complete brake job. The thinner you make them the more they will heat check. Or possibly crack.
shaneomac111
got my parts from pacific trailer > i went ahead and done both sides rotors,seals, bearings, pads
