FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: Trailer brake and turn lights work but not running lights
clean the ground, also check for shorts in the brown wire, that is the wire for the running lights. Also check your brown wire at the truck side to make sure there aren't any shorts.
What is the tow vehicle??? Ford trucks (F150's and Expeditions) have a separate fuse in under hood fuse box which just powers the trailer marker/running lights.
I had the same problem. I found out it was a blown fuse. Checked the fuses
under the hood and found a bad one. Replaced that and brought back my turn signals. Still couldn't get my running lights working. After checking further I found out there is another fuse box under the drivers side rear seat.
Checked there to find another fuse out. That fuse was for the running lights.
I have a 2004 GMC SUV. Check at your rear plug to see if your problem isn't comming from the vehicle.
