Tracking down lack of water flow. (15hp 4-stroke)
spacecased
Hello,
I have a 1998 Evinrude 4-stroke 15hp outboard that I believe i am having water flow issues. I get no water out of the tell-tail and after trolling with the motor for 30 minutes it starts to run rough and has no power.
I changed the impeller which the old one doesnt seem to bad. I have then been following up the intake to see if there are any leaks.
Currently. I have the powerhead off. I am able to blow into the intake and air appears to come out the Water outlet where the thermostat is, and out of the exhaust.
My question is, is water supposed to be coming out of the exhaust? Do i have a bad head gasket or something. What are some things i should be checking at this point. I have the thermostat out for testing. I still get little to no water out the tell-tail. I have verified that the tell-tail is not clogged. Any ideas.
