manaya1127
Thread starter- Joined
- Dec 2, 2020
- 21
Anybody out there have 2000 Sun tracker party Cruiser 32, I just bought one and I have a lot of questions. Mine has the inboard 3.0 135 HP Chevy 4 cylinder, Thanks
Number 1 where can you get parts of anything for this boat as tracker no longer make them, exhaust hose in engine compartment for one the rear cover.What questions?
Do you own one?Number 1 where can you get parts of anything for this boat as tracker no longer make them, exhaust hose in engine compartment for one the rear cover.
just came to mine , I am installing those risers on the railing how are they installed in this type of pontoon wher the enloser isDo you own one?
Requirements are a little higher, but access to get to those "requirements" is considered near impossible on may installations. The little 4 banger I/O isn't as bad as some - like any of the V-6 or V-8 installs....I had wished my 30' Party Hut had inboard till I found out the added maintenance for the inboard was a little higher than the Mercury 100hp outboard. That engine does everything I need. Looking to tune it up and replace the sacrificial blocks.
yes it will be different for me , the room whereit sits is a little tight but i will give a shot.Requirements are a little higher, but access to get to those "requirements" is considered near impossible on may installations. The little 4 banger I/O isn't as bad as some - like any of the V-6 or V-8 installs....
You are so GLAD you went O/B here, especially if you went 4 stroke....
