tracker force power series 50 starting problem
tutley
Just bought a 97 tracker and as luck would have it 2 weeks later it will not start. Going through the threads I have tried a few things and would like some advice before I spend anymore money.
Turn the key and get a click at the solenoid, tried jumping the solenoid with a screwdriver, nothing. Went straight from the battery to the starter nothing. Had the battery checked and bought a starter, same problem except now I can start it running straight from the battery to the starter so I may have jacked that up the first time I did it.
So should I go straight for the solenoid or look somewhere else first. Battery is good, all terminals are good, starter is good. Scratching my head because I wish that dang starter would have started the first time I tried it before I bought a new one.
Thanks for any help.
Tom
Barnacle_Bill
Re: tracker force power series 50 starting problem
When you go from the battery to the starter are you using jumper cables or the existing cables? If you are using jumper cables then the problem can be with the existing cables or the solenoid.
tutley
I am using jumper cables. I disconnected the cable from the selenoid going to the starter and hooked up to that since it hard to get to the post at the bottom of the starter. I also checked the old starter and it is fine.
JB
When you used the jumpers did you jump both the positive and negative cables?
Your symptoms are most commonly caused by hidden corrosion in the ground cable to engine block connection. . .even if it looks clean and is tight. If you didn't jump from the battery ground to the engine block you did not bypass that connection.
tutley
I did not use pos and neg. Tomorrow I will start checking my wires out. I do not understand what you mean by I did not bypass the connection. Does this mean that the solenoid is working? Sorry, I am just getting into this and trying to learn as much as I can. Thankyou for all the responses.
metor99
dosen't that motor have a push in fuse. Mine does. If the fuse is popped you will also get nothing.
tutley
Checked all fuses I can find on that boat and all were good, I did not see a push type fuse anywhere though. I will look it over again tomorrow.
metor99
The fuse im talking about is under the hood usually by the selonid on the bottom part of the motor. It is a little smaller than a match box and black in color. If blown there is a tab to push bach in to reset.
tutley
Thanks a ton metor99, this will definitley help.
tutley
Pulled the ground off the block cleaned it up real good checked it all the way back to the battery, still nothing. I can now jump it from the selenoid and the starter though so I am at a loss of ideas.
Some of you guys may not agree with this but I am going to rig a push button starter straight off the solenoid. I only have about a month or so of good fishing left here in Utah. Then dig into it in the off season.
