towing with chevy 7.4 , 6.5 , 6.0
Mr_Shamrock
Re: towing with chevy 7.4 , 6.5 , 6.0
I don't have any experience with the 6.5's but just about everyone that has says stay away from them (including a 20 year GM tech). Especially with diesel so high now. I have driven many 96 and up 454's and they are my favorite motor all the way around. I used to drive a 99 2500 with a 5.7 that got 16 empty and with just about any kind of trailer the MPG's dropped substantially. It also struggled with the heavier stuff. I currently own a 98 GMC C3500 dually with a 454. I drove it to Florida empty and it got 14.6 MPG. I have driven it with a 20 foot trailer loaded to Atlanta and back and it got 12.4 MPG. We pull our boat with a 96 K2500 Suburban which used to be mine, but my dad bought it from me. It gets 10-11 MPG currently pulling a loaded 22' pontoon (AKA parachute) in the mountains with 8 people in the truck. I will get even better out of it as the injectors are leaking right now. This is a common thing on the Vortec 454's but the good news is they are easy to change and can be bought for $130 a set. I already have them and am just waiting for dad to have a down day to install them. So I obviously vote for the the big block gas burner - they are easy to work on and parts are relatively inexpensive. We have pulled our boat with a 2002 Suburban w/ a 5.3, a 2005 Escalade w/ a 6.0, a 2003 1500HD w/ a 6.0 and although the 6.0's did fine the big block just straight out pulls it better. We hit some pretty steep inclines on our way to the ramp (highway 11 to Lake Keowee) and that 454 handles the inclines like nothing. I couldn't stand how the 6.0's and especially the 5.3 would kick down and rev up on every little hill. To be fair our current Suburban has 4.10's and the rest had 3.73's.
badbowtie
I am glad to here about the 454. I just found a really clean 454 crew cab that I like in my price range I am going to go there tomorrow and see if we can make a deal.
Mr_Shamrock
Things to look for:
Ask about the injectors (if they have been changed)
Check lower intake gaskets in the corners for leaks (ask if it uses any coolant)
Listen to fuel pump to see if it is loud and ask if it has been changed. If it has been changed did they do the pigtail upgrade?
Is the fuel pressure regulator original
These seem to be the common issues. I am a member of a great forum fullsizechevy.com and there is an entire section dedicated to Vortec 454 owners. The above listed items are the known flaws that we see repeatedly. If none of the above have been done you should budget about $600 in parts and if your mechanically inclined they are relatively easy to install. Good luck!
badbowtie
I am a member over at fullsizechevy also. I am aware of those issues I can do all work myself the only thing I have to pay someone to do is alignments.
TilliamWe
Banned
Ah heck, if all you change is a drag link or a tie rod, a tape measure and a grease pencil is all you need! hahaha Good luck to you.
badbowtie
Well I was able to make a deal I got it 99 3500 crew cab dually 4x4. Just need to go over everything and check it all out. Will post pictures hopefully tomorrow.
Mr_Shamrock
Congrats brother - enjoy that bad boy!
