Towing with an Explorer
mikeneal
Re: Towing with an Explorer
I think drawtite is the manufacturethat makes a weight dist hitch that can be used with surge brakes, I have seen them, but not totally sure of the manufcature.
rg33
Originally posted by Njlarry:<br /> I'm confused, can the 3,500 lb explore be upgraded to 5000 lbs by changing to a larger hitch etc?
Not an explorer. I have a 2002 with the towing package, 2" receiver from the factory. Ford adds different rear end 3.73, oil cooler, and stiffer rear suspendsion for the 5000lb. capacity. It would be best to go to a dealership and check the specs for the year of vehicle. Or go to Ford Truck Forum and join/read the discussions on towing and explorer sections.
njlarry
Thanks for the insight. I can add an oil cooler but is the rear end ratio important for flat country towing?
POINTER94
Some may call me crazy but not only a tranny cooler but a temp gauge for the tranny fluid would be a good idea. Brakes can also be oversized with a towing package. The lower gear ratio will make a huge difference.<br /><br />If you get a chance to trailer a load with a 3.55 and then a 4.10 rear end, you wouldn't beleive it. The upgraded suspension helps manage the weight movement as you go through town. I trailer a 6000lb boat with a 2004 expedition and it is rated at 9000lbs. I would rate it as acceptable not great. Lots of fudge figured into these tow ratings.
