Re: Towing in OD OK with this situation?
As an ASE master technician I will say for certain that you will not damage the transmission by towing in OD. as long as the transmission is not hunting for gears constantly you are and will continue to be fine. Tow haul mode on transmission simply increases the pump pressures inside the transmission and makes it shift more firmly. It also downshifts the transmission when slowing and downshift the transmission much sooner when accelerating so it does not lug the engine. On my yukon which has a digital temp gage for the transmission does not drop transmission temp at all by putting it in tow haul mode, it actually increases temps a bit. Temprature is second in importance to transmission slippage, that's why they increase line pressures. I tow my 7200lb boat on the highway all the time in overdrive, and in normal mode as it increases fuel economy tremendously, I simply keep an eye on transmission and engine temps, if the trans starts hunting I put it in tow haul, and that causes it to hold gears longer with much less shifting. Hope this helps.
