Towing car: is this feasible?
JasonJ
Re: Towing car: is this feasible?
Make sure that DeVille isn't front wheel drive. I can't remember which full size older Caddy's were front wheel drive, but they shared the same chassis as the Olds Toronado. I personally would get a truck, more ground clearance, less things to get wet when you back too far into the water. Either way, good luck.....
Raghauler
DeVilles were RWD, El Dorados were FWD.
FlyBoyMark
Ensign
As a weldor with 20+ years in marine and general fabrication: Certain rear wheel full size caddies will NOT accept ANY hitch in the rear...I don't remember which models, but you want to look underneith and SEE a chassie attached to the bumper. Air shocks will work great long as your tung load is less than 300 lbs.
jcac27
Great info thanks guys<br /><br />I went on etrailer and entered the info about the car and two possible hitches came up, so I assume that this is not one of the models that doesnt accept a hitch.<br /><br />Thanks again everyone!!!<br /><br />I think this will be my towing vehicle!<br /><br />James
NMplayer
I used to pull a boat and a small camp trailer with a 79 olds 98. Those cars are meant to ride really well. It may be soft in the rear end. In other words the trailer might squat it pretty good. I put some inexpensive overload springs on it and it solved that.
