Towing another boat long distance, how fast?
Bubba1235
No longer on Forums
Assume a couple of open bow V bottoms of about the same size, call it 20'. Tow will be approximately 32 miles. What would everyone consider the fastest safe towing speed? Would you even consider getting both on plane? (HP is not an issue.)
a70eliminator
Re: Towing another boat long distance, how fast?
On plane while in tow! I don't know I guess it could happen but it sounds dangerous.
md-lucky
I would be FAR more worried about the "whoa" than the "go."
With a long enough rope, it wouldn't bother me to get up on plane.
With a short rope, I would want to keep the speeds very slow just in case either boat needs to make an emergency stop.
Just my humble opinion.
QC
I've seen rental boats on Mead that size under tow and on plane quite a few times. I am guessing 20 MPH max. Just on an efficient plane. I have also seen numerous PWCs towed that fast which are basically smaller v-hulls. Scary, but I think I'd try it with the right equipment.
Ayuh,... Years ago I was towed in by the Coasties,... About 10 miles,... All at 12 mph....
H20Rat
two 20' foot boats... if you try to get on plane you will either 1) not have NEARLY enough power to do that, or 2) will destroy your tow hook or break a bunch of fiberglass.
don't underestimate the power needed, it WILL break something, and keep in mind what a tow rope under load will do when it breaks.
Willyclay
BTDT, once! My 16ft outboard was towed by 62ft houseboat with twin Mercruiser 350's. Towed boat was all over the place without any directional control while on plane. Finally dug into the wake and pulled the bow eye out. Fortunately no other damage and nobody got hurt by the towline. Loading on the trailer was fun. Good luck and be safe!
109jb
Not only is it possible to break something on the boat, but if something does come loose you can have the stretched rope slingshot whatever came loose. Imagine a bow eye or cleat being flung at you from the end of a rope. The faster you go the more tension on the rope.
ondarvr
Just plan on going slow and enjoy the cruise.
There was a post a couple of years ago about bow riders being towed by houseboats, it appeared that its not that uncommon for them to take water over the bow and sink.
This_lil_fishy
Master Chief Petty Officer
The towed boat, depending on hull design, may also rollover at high speed. Not a good plan...slow down..you're not racing the towed vessel so what's the rush?
ian
Home Cookin'
Borrow a trailer.
Some would recommend tying the boats along side. But no planing at that!
You will need someone in the towed boat in case steering is needed, and that is dangerous (and boring). Of course, there's the debate about towing with the motor up, reducing drag but compromising control. If it starts heading to the wake, stop--that's where you swamp and roll.
If you do tow be sure to use a harness that will let the tow rope ride in the middle.
As for stress on the rope, there may be more stress not on a plane than on.
I know of some folks who had to have a long tow; they trolled and caught several good fish on the way back!
BWR1953
Yeah, I'd also say to either borrow or rent a trailer. Even paying $100 for a rental beats sitting in a towed boat for 6 or 7 hours!
Captain Caveman
Right on... Make this a 6 hour fishing trip and it'll be tolerable and safe.
rcracerx
I had a small incident this weekend out in the bay where I needed to be towed. I was with a buddy boat a 2006 Hydrasport 22 WA with a 2006 200HP Evinrude. My boat is a 22 foot walk around. After about 5 minutes of him towing me pretty slow his over heat alarm sounded. Not sure why or if he has other problems but he said he can run all day long WOT and never get an alarm and he said it was because of towing the extra weight?
After that I got on the horn and called Tow Boat to finish up the tow. He told me to put my motor in the water and steer with him, he went slow and took it easy. He said there is no other way to tow without beating up both boats and risking danger. Just a FYI from my personal experience.
Rc
Richiekramer
Right equipment= helmet and boat insurance
QC
I want to clarify what I posted . . . . Mead has Marinas that are related and also 30 miles apart. Sometimes they have rental equipment problems where they have to shuttle boats from one remote marina to another. I have seen them often towing large runabouts, basically 19 footers with 150 OBs. They'll often use another similar boat, or something larger, but they cruise along on plane quite nicely. Obviously they have hardware that is sufficient and some procedures and experience that make it work. It is seeing this over and over that gives me confidence that speed and planing are not hard barriers.
With that said, I have towed a 14 ft. tinny and watched the bow start to go under at around 16 mph, so balance, towing angle (attachment points), speed etc. are all very important considerations. I would never recommend being cavalier in this regard.
Also, what ondarvr says about houseboats and towed support boats is very true. The worst examples I have seen are mid engine, bow rider, tournament ski boats with downward sloped gunnels at the bow. Absolute disaster waiting to happen. I read something about one sinking in Powell like that, but can't find it now.
We have towed behind houseboats forever and the closest I ever came to sinking anything was due to big wind waves not speed. The houseboats we have rented were never capable of more than 10 MPH though, so not real relevant.
roscoe
I know of one rig that has a trailer tongue mounted off the back with the coupler facing aft.
The guy tows his small 14' tinnie behind his 22' deckboat.
He has a reinforced mounting plate on the bow of the tinnie, with a tow ball.
The boat just follows along behind, and he cruises at a pretty good clip to get to some remote areas.
Wish I had a photo.
rbh
watched a couple of guys moving a large wharf (20x20 approx) the wharf was tied to the side of the boat one guy drove the other fished from the couch, while watching TV?
but I would think if you were going to pull a boat use a 30-40 foot rope and mark the line as you dont want some one cutting between you.
it will take you 5 minutes to get up to speed but will take you 20 to slow down, leg up (to stay straight) and I think you should drag some thing for resistance, tabs?
dont be in a hurry
good luck
rob
redfury
And remember the physics on the boat being towed. It isn't being PUSHED through the water like it is designed to be. The engine isn't forcing the nose up.
eli_lilly
Rc
It's because you've effectively doubled the amount of hull being pushed without making a corresponding change in prop pitch.
-E
