Tow master F65-14ST
TnFireMedic
I have a 2005 Trailstar Pontoon trailer that has F65-14st tires currently on it, I have tried ordering these tires and can’t find them anywhere. I’ve been told by a local tire dealer that, that tire would convert to a 205/75/14 however when we mounted on it leaves me absolutely no room in the fender wells, I can’t even fit my fingers between the fender and the tire with the 205/75/14 but with the F65-14ST I have a couple of inches clearance on each side. I’ve considered going to a 205/65/14 but again no luck. Has anyone run into this problem with these tires that came factory with a Tracker boat on trailstar trailer? And does anyone know where I could find a couple of these tires?
Thanks.
bruceb58
205 is the width. The 65 or 75 designates the height. For example a 65 tire is 0.65 x 205.
If your trailer is a tandem axle, have you considered going to a 13" tire? My pontoon uses 175/85/13. This tire is almost exactly the same height as the 205/65/14 tire. Its about an inch or two shorter than the 205/75/14. You would just have to buy some new rims but they aren't expensive.
The only issue could be the load rating if you only have a single axle trailer.
E trailer does carry a load range D with a wheel for $121/each
BTW, my trailer is a Tracker Trailstar as well. It's a 2006 model.
